1994 Toyota Pickup
15,000 MILES • 4 CYL • 2WD • MANUAL
JOHNSONF
what will cause engine not to start? engine turn over, fuel pump is working, throttle position relay is good, will cold start injector cause truck not to start?
May 11, 2008 at 12:15 PM
  • 31,937 POSTS
Hi there, check the cold start injector as they do tend to get gummed up. check fuel pressure and injection pulse, check for voltage at the cold start injector.
Mark (mhpautos)
May 11, 2008 at 5:04 PM
