Fuel filter location
BLUELIGHTNIN6
  • 16,542 POSTS
You have to use a back-up wrench to remove fuel line from filter. Then disconnect quick-connect fitting from filter and remove fuel filter from mounting bracket.
Thanks for using 2CarPros. Com!
Tuesday, June 11th, 2019 AT 2:08 PM (Merged)
CRITTER4X4
  • 2002 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 159,000 MILES
2002 Chevy Malibu hesitation on acceleration. I have replaced the fuel filter also ran two tanks of gas with fuel injector cleaner.
Tuesday, June 11th, 2019 AT 2:09 PM (Merged)
  • 31,937 POSTS
Hi there,
I would first do a scan to check for any unresolved fault codes, not all faults will trip a MIL.
Mark (mhpautos)
MIRANDA03
  • 2000 CHEVROLET MALIBU
Ran car out of gas, replaced dirty fuel filter and car still wont start
  • 109,885 POSTS
Have you checked to see if the fuel pump pressure is within spec? I have seen many go bad when a car is run out of gas.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 CHEVROLET MALIBU
  • 125,000 MILES
What are the symptons when your fuel filter needs replacement
DRCRANKNWRENCH
  • 3,380 POSTS
Poor performance or loss of power
slow to rev or decrease in RPMs
Low fuel pressure
Check the plugs and see what color they are. They should be tan/brown if the engine is running well, black if it is too rich, and, what you will be looking for if the fuel filter is very clogged, white.
The best way to determine is to run a fuel pressure test. But that is often just as time consuming as replacing a filter in most cars.
FATSD59
Engine Performance problem
2000 Chevy Malibu 6 cyl Automatic
i wanted to know how do I know the fuel filter is completely depressurized I removed the relay and it stalled out but the instructions said to crank it again for 3 sec but my car wont crank again is it already good to work on
Tuesday, June 11th, 2019 AT 2:10 PM (Merged)
ERNEST CLARK
  • 1,730 POSTS
All you need to do is crank it while you are removing the relay. Once it stalls out, there's no more pressure in the fuel lines. (But there is still fuel, so be careful)
