Hi. This could be ecm fuel pump crank sensor elec wireing prob. They must have tested fuel pressure. Or they would not know if it was the pump or not. You need to know these things
#1 fuel pressure
#2injrctor pulse tested with noid light should flash
#3spark tested at the spark plug
when it won, t start check these things this will tell you why it won, t start billymac
SPONSORED LINKS
Wednesday, April 15th, 2009 AT 6:45 PM
