Fuel filter location?
BUD0529
  • 1998 DODGE RAM
  • V8
  • 4WD
  • 122,000 MILES
Is the fuel pump and filter located on top of the gas tank on a 1998 dodge ram 2500 reg cab (5.9 360)?
Thursday, August 27th, 2020 AT 12:06 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
YEah, nice place huh? You'll need to drop the tank to get the pump out. The filter/regualtor assy is on top on the module fuel pump module.
https://www.2carpros.com/forum/automotive_pictures/30961_zfilt_1.jpg
STEVE MLADY
  • 1998 DODGE RAM
  • V8
  • 4WD
  • 140,000 MILES
Where is the fuel filter on a 318 emgine located
CH112063
  • 1,320 POSTS
The fuel filter is in line on the pressure side of the fuel system. It is near the fuel tank, mounted on the frame, you can follow the larger fuel line back from the engine, or out of the fuel tank to locate it. On every 98 318 injected truck, you must de-pressurixe the system before replacing any component in the system and use care for your eyes. I always recommend disconnecting the negative battery cable for safety. Ok Joe
JSWAIN
  • 24 POSTS
I thought the fuel filter on those trucks was just a sock, or mesh screen, inside the gas tank around the fuel pump?
CH112063
  • 1,320 POSTS
Hello, every tank does have an initial screen to protect the pump internal parts, a screen, or sock as it is called. But unless your truck has something different, the filter is in the 5/16ths pressure line(8mm) a couple yards down toward the engine. It is a 36,000 mile change recommended. Never saw one without one because of the cost of injector and engine damage under warranty. OK It has the fittings you use a push in tool(pliers) for. OK Steve. Maybe they ran out of them and changed it. New to me. Put one on friday. Good truck. If you haven, t had pump(fuel) problems good. There were some problems with the in tank pumps, but I only see the bad ones so I would not be too concerned.
MJARNOLD
  • 1998 DODGE RAM
  • V8
  • 4WD
  • 70,000 MILES
Where is the fuel filter located? I would like to change
I have been told that this could be my problem. Truck runs welll and at times is will run very rough.
When I rep it up it clears.
Thanks
The fuel filter/fuel pressure regulator is located on top of fuel pump module.
https://www.2carpros.com/forum/automotive_pictures/12900_fuelfilter_1.gif
