Will not start, possible Fuel filter issue?
250,000 MILES • V6 • 2WD • AUTOMATIC
MICKIMARIE PUNTIGAM
My car won't start, the symptoms sound like my fuel filter needs to be replaced. AutoZone told me the fuel filter for my car is non-serviceable, what does this mean?
Apr 28, 2023 at 10:47 AM
  • 110,248 POSTS
The fuel filter is located in the fuel tank and integral to the fuel module.
An easy way to check if it is a fuel-related issue is this. See if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is fuel related.
If there is no change, I need you to check for a spark at the plugs.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
As far as the fuel filter is concerned, normally, you will notice issues prior to it plugging. Did you experience power loss, a delayed start, or anything other that was odd?
Apr 28, 2023 at 5:41 PM
MICKIMARIE PUNTIGAM
My car was kind of bogging out and giving me a hard time to start up for a about a week before it just decided to stop starting. I went to the store and my car just wouldn't start to go home.
Apr 28, 2023 at 9:08 PM
  • 110,248 POSTS
If it is presently not starting, see if it does with starting fluid. If it starts and then stalls, we know its fuel related. If it doesn't make a difference, then we need to check for ignition issues as mentioned.
Ler me know if the mileage you indicated is the actual mileage on the engine.
Apr 29, 2023 at 12:07 PM
