Poor fuel mileage
120,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
JESSIE473
  • 24 POSTS
Still gets ten mpg, has not set any codes, runs and starts perfect. Just can't get over ten mpg. Could it have something to do with exhaust? it has a slight vibration at idle i can feel in the steering wheel only. thanks for any advice you can give me.
Mar 14, 2019 at 7:26 AM
Good afternoon,
Fuel mileage has a lot to do with driving habits. Short runs give you less miles.
Tires are a factor, alignment and the transmission working correctly are key factors as well.
Mar 14, 2019 at 7:31 AM
AHMAZEZING
A slight vibration at idle could be a misfire that the computer isn't reading. Bad o2 sensors can also result in bad gas mileage. Usually a bad O2 Sensor will give a Check Engine Light.
The best option would be to have someone scan the computer for codes, or scan them yourself if you have the tool.
A standard tune up with spark plugs, wires, and rotor cap and button are a good place to start if you haven't done this recently.
Mar 14, 2019 at 7:50 AM
A bad O2 sensor would give you other symptoms.
There most likely is nothing in the computer. You would have check engine light if there were some readings that were off.
This is a basic issue as I discussed.
Mar 14, 2019 at 9:14 AM
