i have replaced front driver side CV axle after blowing the joint. i assembled it correctly using all torque specs and now the front end wobbles. ball joint seemed good as well as the wheel bearing the tie rod end was stiff but not froze or anything. plus the brake pedal goes to the floor. There are no leaks and never disconnected the line. Any thoughts?
Feb 13, 2018 at 9:45 PM
