Front end jumping while in reverse with the wheels turned all the way
110,000 MILES • 0.6L • 4 CYL • 2WD • AUTOMATIC
CATHERINE ROBERTS
When I am in reverse with the wheels turned all the way, there is a repeating jump in the front end and a soft knock that goes with it. It is getting worse, but does not always happen. Also, I have an EGR light that continues to go on and off. everything in the system has been replaced by the dealership that had to do with the EGR including the cars computer, catalytic converter, she valve etc., the light can go on or off after a hard bump sometimes. Thank you for being auto rescue angels.
Dec 8, 2016 at 2:07 AM
  • 55,770 POSTS
Hi CATHERINE,
This sounds like you have a CV axle that needs replacement. What happens is the CV joint becomes worn and it binds when in a full turn.
Here is a guide and video on how to replace it.
https://www.2carpros.com/articles/replace-cv-axle
and
https://youtu.be/vOVpWpXsJfk
Please let us know happens so it will help others.
Best, Ken
Dec 8, 2016 at 8:04 AM
