2000 Ford Explorer Won't Idle
DSLAGER
2000 Ford Explore with a 4.0 engine. Car wouold start but would not stay running at idle speed. Turned the idle screw up to where oit would idle normal knowing that wasn't going to fix the problem but would get me thru the day. Car ran fine that day but if you revved the engine it would come back to a high idle for a couple seconds and then to a normal idle. The next day the car won't idle again.
Nov 17, 2006 at 4:17 AM
LOSONE
  • 1,616 POSTS
90% of your idle problem is caused by the Idle Air Controller which is a silver module about the size of 2 flashlight batteries located in the inteake plenimum.
Remove the module and clean the carbon from the open are aon the bottom. Use a good grade of carb cleaner. Let it dry and replace it.
Another cause could be your Mass Air Flow Sensor. They often get debris that cause idle problems. Something as small as a cat hair can be a problem.
Good Luck
Nov 17, 2006 at 7:39 AM
Suggested Repair
Remove the idle air control valve from the intake plenum, clean carbon from the opening with carburetor cleaner, let it dry, and reinstall it. Also inspect and clean the mass airflow sensor, since even small debris can cause idle problems.
Conversation Summary
The owner of a 2000 Ford Explorer 4.0 says the engine starts but will not stay running at idle. Raising the idle screw temporarily allowed normal idle, though the engine returned to a high idle briefly after being revved, and the idle problem returned the next day. The expert says most such idle problems come from the idle air controller and recommends cleaning carbon from it, while also checking the mass airflow sensor for debris.
