Ford Windstar Inertia Switch After Wreck
MONISHA JACKSON
where is my car button to press when you have a wreck and your car won't start
Feb 25, 2006 at 2:54 PM
JPAM
  • 307 POSTS
Please write more info YEAR, MAKE, MODEL, MOTOR SIZE and milage... BUT IM thinking u might be looking for your EASY BUTTON i mean *OnStar....
Dont know my way around newer Fords & If they came with *OnStar now?? BUT anyway more info would help out alot.. thnks
Feb 25, 2006 at 5:19 PM
DB554
  • 35 POSTS
usally in the trunk on the left hand side.
Feb 25, 2006 at 10:45 PM
JPAM
  • 307 POSTS
fuel-pump inertia switch: A normally closed, manually reset switch that opens if the vehicle is involved in an impact over 5 mph, or rolls over, turning off power to the fuel pump. This safety feature prevents fuel from being pumped onto the ground or hot engine components if the fuel line is ruptured or the engine dies.
Now i know what was being talked about here :)
Feb 28, 2006 at 3:33 PM
Suggested Repair
Reset the fuel-pump inertia switch, usually located in the trunk on the left-hand side. After an impact over about 5 mph or a rollover, this switch opens and cuts power to the fuel pump until it is manually reset.
Conversation Summary
The owner of a Ford Windstar asked where the button is to press after a wreck when the vehicle will not start. Experts identified the fuel-pump inertia switch, which opens after an impact or rollover and must be manually reset, and said it is usually in the trunk on the left-hand side.
