1997 Mercury Villager Cold Start Issue
AUTO20878
My wife's mini van has this problem.
Here is history that might help with the answer.
Before all these problems, I took the dealer's advise to perform "power flush" to transmission. Later, someone told me that power flush might damage something. Few months after the flush, here comes the problem.
Once, the car won't start. The only way to start it is turn the key and push the pedal at the same time. Ford dealer replaces some sensor. It seemed worked for a while. Then few weeks later, the fuel pump went out. It got fixed as well. However, the following problem seems to persist.
When starting the engine the very first time in a day,
it starts slow then within 2-3 second it would rev up to the normal condition. BY slow, I mean, it got started then dies down a little bit, then picks up again. This only happens the first time in a day. After that, it would start like it supposed to be for many hours after a short driving. I guess the problem only exists when the engine in completely cold.
Any advise would be appreciated.
Philip
May 3, 2006 at 1:13 PM
PEPPERMRJ
  • 1,158 POSTS
If you did not already replace the fuel pump that would have been my first thought. I mght still have the fuel pressure checked. Double check the fuel lines/connections for any leaks. Try a fuel injector cleaner. Maybe even a new fuel filter.
Good luck and let us know. :)
May 6, 2006 at 9:15 AM
Suggested Repair
Check fuel pressure and inspect fuel lines and connections for leaks. Replace the fuel filter and try a fuel injector cleaner. The fuel pump was already replaced.
Conversation Summary
The owner of a 1997 Mercury Villager reports that the first cold start of the day begins, dips briefly, then recovers within a few seconds. Later starts are normal. After a transmission power flush, a sensor and the fuel pump were replaced. The expert suggests checking fuel pressure and lines, replacing the fuel filter, and using injector cleaner.
