1995 Mercury Villager No Start
IAMJOHNGALT1968
My '95 Merc. Villager wont start. It started overheating, then started running rough, then it died on the road. It has 126,000 miles on it and it is a 6 cyl. engine. I though I siezed it but a couple of weeks ago I got it started and it ran for 30 mins. No smoke and it sounded great. I turned it off and it hasn't started since. After I turned it off, all the hoses flattened out like there was a vacuum effect going on. It turns over, but it wont start. Is this a cat. con. problem. I'm puzzled by the flattened hoses.
Apr 13, 2007 at 6:21 AM
MERLIN2021
  • 17,250 POSTS
Take a rubber hammer and pound on the converter and muffler, any rattle? Then check the oil level see if you are at the right level, not over full!. If that's ok disconnect the exuast and see if it starts...
Apr 15, 2007 at 1:31 AM
Suggested Repair
Tap the catalytic converter and muffler with a rubber hammer and listen for a rattle. Check that the oil level is correct and not overfull. If those checks are fine, disconnect the exhaust and see whether the engine starts.
Conversation Summary
A 1995 Mercury Villager with a 6-cylinder engine and 126,000 miles overheated, ran roughly, and died. It later started and ran well for about 30 minutes, but would not restart after being shut off. The owner noted flattened hoses suggesting a vacuum effect and asked whether a catalytic converter problem could prevent starting. The expert advised checking the converter and muffler for rattles, verifying the oil is not overfull, and disconnecting the exhaust to test whether the engine starts.
