2002 Ford Windstar Engine rough
50,000 MILES • 6 CYL • FWD • AUTOMATIC
SEH
Myengine very occasionaly runs rough when when first start it. It sounds like one cyclinder is misfiring. No lights in the dashcome on. It will smooth out after you start moving. It will also run smooth if oyu immedialty turn it off and restart.
Jan 17, 2009 at 3:34 AM
  • 110,248 POSTS
This is a tough one to diagnos without an engine light coming on. You may want to check fuel pressure when the vehicle would normally do this. Anything else would be a guess at this point. If the condition worsens, it should set a code in the computer. Then you can identify the problem.
Jan 23, 2009 at 10:23 AM
