2002 Ford Windstar Engine Light
JENN_1982
  • 2002 FORD WINDSTAR
Engine Performance problem
2002 Ford Windstar 6 cyl Front Wheel Drive Automatic
Engine light is on we just change spark plugs and it back fires when takeing off and sputtering and it;s really been sucking gas. It never was like this before
Sunday, January 17th, 2010 AT 12:13 PM
Scan the computer for codes, there's a problem within the Engine Management System. This is your starting point to finding out the problem.
Sunday, January 17th, 2010 AT 2:46 PM
JENN_1982
  • 8 POSTS
What do u mean computer Codes?
Sunday, January 17th, 2010 AT 3:54 PM
What light is coming On? Is it the CEL/SES/MIL?Did your problem arises after you replaced the plugs-
Sunday, January 17th, 2010 AT 3:59 PM
JENN_1982
  • 8 POSTS
Yes after the plugs it came on. And all the rest as well the back firing and gas gazzeling
Sunday, January 17th, 2010 AT 4:19 PM
Get the computer scanned for OBD2 code/s this is your starting point finding out what's wrong
Sunday, January 17th, 2010 AT 4:21 PM
JENN_1982
  • 8 POSTS
Ok what computer do I scan for that code. Imreally lost can you clear up a few lost areas?
Sunday, January 17th, 2010 AT 4:48 PM
The computer is called the PCM
Your best bet is bring it in- it can be complicated and if the codes not interpreted right it can be a nightmare to remember-No joke
Sunday, January 17th, 2010 AT 5:02 PM
