2002 Ford Windstar Squeal Then Stall
OKBAR
Need help diagnosing a recent problem with my van. The van will intermittently make a "squealing" noise (sounds like the power steering pump??) and then will go dead. No noted leaks, overheating, etc. I have had power steering pumps go bad before, but never cause the vehicle to stall out. Any help would be appreciated. Thank You.
Oct 16, 2007 at 5:09 PM
SERVICE WRITER
  • 9,123 POSTS
Get a look at the pulleies that the serp belt goes around. Look for an accumulation of black particles the seem to concentrate of one of them. One of them sounds like thay are seizing up.
Oct 17, 2007 at 12:55 AM
Suggested Repair
Inspect the serpentine belt pulleys for black particle buildup concentrated on one pulley, which can indicate a seizing pulley. Replace the failing pulley or related belt component as needed.
Conversation Summary
A 2002 Ford Windstar with about 50,000 miles intermittently squeals, possibly like a power steering pump, then stalls. There are no leaks or overheating. The expert advised checking the serpentine belt pulleys for black particles concentrated on one pulley, suggesting one may be seizing.
