1998 Ford Windstar Dies When Stopping
TASHA
I have a 1998 ford windstar and I am having a big problem everytime you go to stop it will die on you unless you use the 2 foot method and keep a foot on the gas and the brake I have replaced the IVF I think it is call the iginition modules something like that it is on top of the motor can you help me please ..
Thanks alot
Tasha
May 7, 2007 at 6:25 AM
MERLIN2021
  • 17,250 POSTS
Check your idle air controller (IAC) and the Mass air flow sensor...
May 7, 2007 at 6:54 AM
TASHA
[quote:a2f42e5b4f="merlin2021"]Check your idle air controller (IAC) and the Mass air flow sensor...[/quote:a2f42e5b4f]
Thanks alot I will try this and let you know THANKS A BUNCH !!!!
May 7, 2007 at 7:19 AM
Suggested Repair
Check the idle air control (IAC) valve and the mass air flow (MAF) sensor.
Conversation Summary
The owner of a 1998 Ford Windstar reported that the engine dies when stopping unless the throttle is held with one foot while braking. An ignition module on top of the engine had already been replaced. The expert recommended checking the idle air control valve and the mass air flow sensor, and the owner planned to try that.
