stalls after only driving a few minutes
170,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
ADEOYEIDRIS
i just bought this van, after driving for a few minutes and want to take a turn it stalls, immediately i put it in park and starts again it picks up. i also observed it when i apply brakes on rough roads it stops suddenly. i have changed the fuel pump three times but no change in the condition. what could be this problem? please i need good advice because it has cost me a lot.
Nov 23, 2016 at 1:46 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner. then scan for codes auto parts does for free
Nov 23, 2016 at 4:22 AM
ADEOYEIDRIS
thanks hmac 300 i appreciate i will do that and i will back to you
Nov 24, 2016 at 5:29 PM
  • 55,770 POSTS
While the engine is running grasp the engine wiring harnesses and move them around. If the engine dies there is a short nearby where you have moved the harness.
Please let us know happens so it will help others.
Best, Ken
Nov 26, 2016 at 12:14 PM
