2000 Ford Windstar Lean Code and Hesitation
CONFUSEDANGEL
2000 Ford Windstar 104,147 3.8L. I bought this van about 2 and a half years ago and about one month after I bought it the check engine light came on, my husband changed the air filter, maf, and O2 sensors, the light went off for about a week and has been on ever since we cannot figure out why it is on, I took it to get the codes read and it is still saying system is running too lean, what do you think it could be. While driving it hesitates, is sluggish and spongy, what do you think is causing all these problems, how much do you think it would cost to have it fixed?
Oct 2, 2007 at 4:03 AM
BOOTDOG
  • 665 POSTS
have you ever changed the fuel filter? a clogged fuel filter will set a running lean code and make the vehicle run sluggish. change the filter and see if that helps. it's a very inexpensive fix. good luck
Oct 2, 2007 at 9:44 AM
TC88
sounds like you need to replace your plenum gaskets. commn problem with 3.0 liter 6 cyl. about 150 for parts, 3-5 hrs for labor if yu do yourelf. not too difficult. found a story/pictorial on the net on how to diy :D
Jan 21, 2008 at 10:39 AM
Suggested Repair
Replace the fuel filter first. A clogged filter can set a lean code and cause sluggish, hesitant running, and it is an inexpensive check.
Conversation Summary
A 2000 Ford Windstar 3.8L has a persistent check-engine light with a system-too-lean code, plus hesitation and sluggish, spongy performance. The air filter, MAF sensor, and oxygen sensors were already replaced. An expert advised checking and replacing the fuel filter as an inexpensive possible cause. Another comment suggested intake plenum gaskets, but referred to a 3.0L engine rather than this 3.8L.
