2000 Ford Windstar Idle Stall Feel
HEATHER8506
My Ford Windstar van sometimes feels like it is going to stall whenever the car is stopped. It failed emissions because it was running lean. The RPM needle bobs up and down when it feels like it is stalling. I replaced the rear o2 sensor, should I replace the fronts too or could it be an entirely different problem?
Apr 27, 2007 at 6:25 AM
SQM
  • 6,383 POSTS
There could several reasons why the engine is running rough.
Many times with drivability issues the check engine light get triggered.
Is your engine light illuminated?
If so getting the vehicle scanned for trouble codes can help with the diagnostics.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Few items you can check make sure they are in good condition.
Check the mass air flow sensor, if it is dirty it can impact the way the vehicle idles. You can clean out that sensor.
https://www.2carpros.com/articles/mass-air-flow-service
Also if you have a dirty idle air control valve it can negatively impact the idle as well.
Larger air particles will get stuck inside the vale and restrict air flow, causing the idle to fluctuate or drop.
The idle air control valve can also be cleaned to restore performance.
https://www.2carpros.com/articles/idle-air-control-valve-service
Sep 16, 2021 at 4:28 AM
Suggested Repair
If the check engine light is on, scan for trouble codes. Inspect and clean the mass airflow sensor and idle air control valve, which can cause a rough or fluctuating idle.
Conversation Summary
A 2000 Ford Windstar sometimes feels like it will stall when stopped, with the RPM needle bobbing, and it failed emissions for running lean. The rear oxygen sensor was already replaced. The expert said several issues can cause a rough idle, recommended scanning for codes if the check engine light is on, and suggested checking and cleaning the mass airflow sensor and idle air control valve.
