1999 Ford Windstar Engine and Unknown Source of Noise
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAD11658
I have two noises going on with my van. The first is a thrumming sound that only seems to happen when driving down the road when the gas pedal is pressed or the cruise control is on. It sounds like a baseball card in the spokes of a bicycle. It will last for a few minutes then stop. A few minutes later it will start up again then stop again. This will last for as long as I am driving down the road. If I take my foot off the gas pedal the noise will stop. The second noise happens when the car had been parked and is turned of. There is a steady ticking noise. This sound will only last a minute or two. Any suggestions?
May 20, 2010 at 1:38 PM
  • 110,248 POSTS
The ticking noise when you shut it off could be the exhaust system cooling and contracting. As far as the noise you hear under accelleration, have you checked the front CV joints? Wheel bearings...?
Jun 24, 2010 at 5:00 PM
