There has been a fairly major failure somewhere, I would be checking that the oil filter is fight and the sump plug is fitted, the white smoke will be coolant, but the oil is a concern, don't try and run the engine till there is coolant and oil in it, and if it make an odd noise shut it down and get it towed, you will need to wash it down and check out where the oil is coming from first.
Mark (mhpautos)
SPONSORED LINKS
Monday, January 5th, 2009 AT 1:51 AM
