1996 Ford Windstar Battery Drains
PRCHULO1
1996 Ford Windstar mileage: 105000. My Windstar runs on just battery power. I have changed the alternator with an original one from a dealer that my buddy works for. It will run for about 15/20mins on a fully charged battery before the battery is completely drained.is there a regulator or something else that might cause this problem Do you have any suggestions?
Aug 27, 2006 at 4:49 AM
TAURUSWHEEL
  • 718 POSTS
Have the charging system diagnosed by someone experienced,, obviously the alternator is not charging the battery,, on your car, I'm not sure if the regulator is integral to the alternator, or maybe a fusible link is burned out.. Is it a new battery???? 20 mins sounds like an old one,, new should last at least 2 hrs with no accessories running, that's what's known as reserve capacity, usually expressed in minutes on the battery label,, in case the alt dies on the road, at least car can be driven possibly to a safe location,, lights, ac, will decharge it quickly..
Aug 27, 2006 at 5:24 AM
Suggested Repair
Have an experienced technician diagnose the charging system. The alternator is not charging the battery; check whether the regulator is integral to the alternator, inspect for a burned fusible link, and verify battery condition and reserve capacity.
Conversation Summary
A 1996 Ford Windstar with 105,000 miles runs only on battery power and dies after about 15-20 minutes even after an OEM alternator replacement. The owner asked whether a regulator or another part could cause this. The expert said the alternator is not charging and recommended a charging-system diagnosis, noting a possible integral regulator or burned fusible link, and suggested the short runtime may indicate a weak battery rather than normal reserve capacity.
