Ford Thunderbird Fuel Injector Fuse Melts
THUNDERBIRDGUY
I Have a ford thunderbird 4.6l V8. and i bought it from a used dealership. Well the fuse for the fuel injecter keeps burning up. it gets melted....Should i use a higher amp fuse....Any help thanks[/b][b:796999a25a][size=18:796999a25a][/size:796999a25a][/b:796999a25a]
Jul 6, 2006 at 12:28 AM
TAURUSWHEEL
  • 718 POSTS
Are you using the correct size fuse to start with??? If yes, do not use higher amperage, may exacerbate whatever problem is causing the fuse to fail, may start a fire.. take it back where you bought it, tell them to fix it..
Jul 6, 2006 at 2:19 PM
Suggested Repair
Do not install a higher-amp fuse. Confirm the correct fuse rating is used, then return the Thunderbird to the selling dealer so they can find and repair the electrical fault causing the fuel injector fuse to melt before it starts a fire.
Conversation Summary
The owner of a Ford Thunderbird 4.6L V8 says the fuel injector fuse keeps melting and asks whether a higher-amp fuse should be used. The expert says to verify the correct fuse size first, warns that a higher-amp fuse can worsen the problem and start a fire, and recommends taking the car back to the dealer for repair.
