1995 Ford Thunderbird Fuel Injector Location
JDCPJC
  • 16 POSTS
Where are the fuel injectors? I have an ohm meter but can't see where the injectors are located...
Dec 11, 2006 at 8:05 AM
CARUNDELL
  • 602 POSTS
[quote:247973ef44="jdcpjc"]Where are the fuel injectors? I have an ohm meter but can't see where the injectors are located...[/quote:247973ef44]
Hey jd,
Whats the engine size. 3.0, 3.8, 5.0?
Chris
Dec 11, 2006 at 8:07 AM
JDCPJC
  • 16 POSTS
Its a 3.8
Dec 11, 2006 at 9:23 AM
CARUNDELL
  • 602 POSTS
[quote:2c5bbcc92c="jdcpjc"]Its a 3.8[/quote:2c5bbcc92c]
Hey jd,
Then the injectors will be on the fuel rails (left and right) with very little in your way,well maybe the harness but easy to move.
Chris
Dec 11, 2006 at 9:27 AM
JDCPJC
  • 16 POSTS
Do you know of any way I can get ahold of a pic? I have no idea where the fuel rails are??? ha ha/...I'm green at this stuff ya know..
Dec 11, 2006 at 9:30 AM
CARUNDELL
  • 602 POSTS
[quote:50a07d903b="jdcpjc"]Do you know of any way I can get ahold of a pic? I have no idea where the fuel rails are??? ha ha/...I'm green at this stuff ya know..[/quote:50a07d903b]
jd,
Uuuuummmmm don't know of any site off hand with a pic. Try this ......I'll assume you have the air ducting removed from the throttle body. To the right and left of the throttle body you will see two chrome lines running front to back on the engine, under these lines @ 3 separate spots are the injectors (they attach in the fuel rail) on each injector is the electrical connector. hope this helps!
Chris
Dec 11, 2006 at 9:38 AM
JDCPJC
  • 16 POSTS
ok got it....thanks so much for the help. I'm goin to check it out first thing tomorrow...
Dec 11, 2006 at 9:43 AM
CARUNDELL
  • 602 POSTS
[quote:fccad061b8="jdcpjc"]ok got it....thanks so much for the help. I'm goin to check it out first thing tomorrow...[/quote:fccad061b8]
My pleasure! Let me know if I can help you further!
Chris
Dec 11, 2006 at 9:52 AM
Suggested Repair
On the 3.8, locate the injectors on the left and right fuel rails beside the throttle body. With the air ducting removed, look for two chrome lines running front to back; the injectors attach under those lines at three spots on each side and have electrical connectors for ohm testing.
Conversation Summary
The owner of a 1995 Ford Thunderbird 3.8 could not find the fuel injectors to test them with an ohm meter. The expert explained that the injectors are on the left and right fuel rails, under two chrome lines running front to back beside the throttle body, with an electrical connector on each injector. The owner confirmed the location was clear and planned to check them.
