1993 Ford Thunderbird Vibration Hum
FORD
ROCKN39
93 t bird i got a vibration/humming sounds like the front when driving straight but stops while cornering, is it front bearing?
Dec 25, 2006 at 7:45 AM
SERVICE WRITER
  • 9,123 POSTS
A wheel bearing going bad will do as you describe. It mimics a tire that is feathered or real choppy producing a hum. When turning one way or the other the noise will stop. It will get worse and likley start becoming more obvious.
Dec 25, 2006 at 11:06 AM
Suggested Repair
Inspect the front wheel bearings. A failing bearing can cause a hum or vibration when driving straight that stops when turning, and it may worsen. Also check the tires for feathered or choppy wear, which can produce a similar noise.
Conversation Summary
The owner of a 1993 Ford Thunderbird reports a front vibration and humming noise when driving straight that stops while cornering, and asks if a front wheel bearing is the cause. The expert says a bad wheel bearing matches that pattern, can sound like a feathered or choppy tire, typically quiets when turning one way or the other, and will likely become more obvious.
