1997 Ford Thunderbird Front Rattle
JASONHARJO
97 Ford Thunderbird, 132K miles, 4.6L V8
I have a rattle sound coming from the front suspension of my car. I took it to a local mechanic. He told me I needed to replace my rack and pinion. Is it common for the rack and pinion to wear like this? I do many repairs on my car and I was wondering how hard it is to replace the rack and pinion and the lower ball joints?
Jul 31, 2007 at 4:54 AM
JASONHARJO
I apologize for the limited info. Thanks for the quick response. The rattle noise happens at all speeds and only when I hit bumps, large or small it doesn't matter.
Also while driving on the highway at high speeds the stearing wheels shimmy's back and forth ever so slightly but very noticable.
I know the lower ball joints are bad but they aren't causing the noise. I will replace them when I replace whatever is causing the noise.
I have never replaced my front struts or my rear shocks.
Jul 31, 2007 at 5:34 AM
  • 55,849 POSTS
I have seen the sway bar links cause this noise and they are easily to replace FYI.
Apr 28, 2025 at 5:17 AM
Suggested Repair
Inspect and replace the sway bar links, a common and relatively easy fix for front suspension rattle over bumps. Also replace the known bad lower ball joints; the rack and pinion may not be the primary cause.
Conversation Summary
A 1997 Ford Thunderbird with 132,000 miles has a front suspension rattle over bumps at all speeds and a slight steering-wheel shimmy at highway speeds. A mechanic recommended a rack and pinion, and the owner knows the lower ball joints are bad but says they are not the noise source. The expert notes that worn sway bar links commonly cause this rattle and are easy to replace.
