1997 Thunderbird front suspension
TONY57
My 1997 Ford Thunderbird LX (90,000 miles) pulls to the right when breaking. I have replaced the front rotors and pads and the dealer says the calipars are working properly. When driving the stearing is stiffer than normal and appears to have a "memory" when turning. The dealer says this is due to the rubber gromets in the control arms being dry rotted and the suspension moves when braking. The dealer says the control arms, ball joints, and all gromets need replaced for a cost in excess of $1,000. Could this be a different problem? I love this car and really want to keep it maintained. Its the best driving car I have owned. I like it so much that when my 1996 was totalled, I found and purchased this 1997.
Oct 26, 2007 at 1:12 AM
MERLIN2021
  • 17,250 POSTS
Are you hearing squeaking noises up front? When control arm bushings are bad they squeak un merciflly!
Check the brake calipers again if no noise! or the hoses. Bad front end, tires or brakes can cause these symtoms tho!
Oct 26, 2007 at 8:41 AM
