1992 Ford Thunderbird Stuck in First
FL_NEWCOMER27
  • 6 POSTS
I just put a motor and transmission in my car... the motor runs great but the transmission wont shift out of first it has new fluid in it and it is full... the motor and tranny sat for atleast 3 months... could it just need to be driven or could it be something more serious...
Feb 13, 2007 at 11:03 AM
TAURUSWHEEL
  • 718 POSTS
Have the linkage checked to make sure it's oriented properly, then a local reliable trans shop hook it up for some testing, also see if any trans codes are there,, if you had an obdI code reader, you may be able to pull some trans codes, if any, yourself,, doesn't sound too good right now.. any warranty with that trans???
Feb 15, 2007 at 2:56 PM
Suggested Repair
Check that the shift linkage is oriented properly, scan for transmission codes with an OBD-I reader, and have a transmission shop test the unit. Also ask whether the transmission is under warranty.
Conversation Summary
The owner installed a motor and transmission in a 1992 Ford Thunderbird. The engine runs well, but the transmission will not shift out of first despite being full of new fluid after sitting at least three months. The expert recommends checking linkage orientation, scanning for transmission codes, and having a shop test the transmission, and asks about warranty coverage.
