I have also had this same problem with this year model tranny. Once a rebuild @ over 1700 dollars and a year later the same thing. I found an answer that, so far, has worked for me on a Lincoln forum. No, it wont make a bit of sense, but as I said, its working.
Replace the NEUTRAL SAFETY SWITCH and advise me of any good results. They are inexpensive and a much better fix than a rebuild that you dont need.
Hope this works for you as it has for me.
SPONSORED LINKS
Monday, November 5th, 2007 AT 7:37 PM
