1987 Ford Thunderbird Won't Start
KALE
The car has power to everything but when I try to start the car, I get nothing. No clicking sounds or anything. When turning the key I don't lose power to my radio, windows or anything. When they key turns, nothing happens the engine doesn't attempt to start and no noise is made. Just dead silence.
Mileage is 100k+
Aug 21, 2006 at 6:28 AM
MIKEYBDMAN
  • 623 POSTS
[quote:3cf0fbff0d="kale"]The car has power to everything but when I try to start the car, I get nothing. No clicking sounds or anything. When turning the key I don't lose power to my radio, windows or anything. When they key turns, nothing happens the engine doesn't attempt to start and no noise is made. Just dead silence.
Mileage is 100k+[/quote:3cf0fbff0d]
If noting happens, the fastest way to trouble shoot is to check and see if power is gettig supplied to the Starter realy from the ignition switch. If you have power when the ignition switch is in the start position, then it is probably a bad relay or starter. If you dont have power, it is either a bad ignition switch, or neutral safety switch or anti-theft problem.
Aug 21, 2006 at 7:24 AM
Suggested Repair
Check for power at the starter relay with the ignition in start. If power is present, suspect a bad relay or starter. If not, check the ignition switch, neutral safety switch, or anti-theft system.
Conversation Summary
The owner of a 1987 Ford Thunderbird with over 100,000 miles says the car has power to accessories but does nothing when the key is turned to start: no click, no cranking, and no loss of radio or window power. The expert advises checking whether the ignition switch supplies power to the starter relay in the start position. Power present points to a bad relay or starter; no power points to the ignition switch, neutral safety switch, or an anti-theft issue.
