1994 Ford Thunderbird No Start
POET042005
  • 134 POSTS
1990/1994 ford thunderbird 3.8 140,00 miles
I have a 94 t-bird with a 1990 3.8 engine that I installed and modified along with a 1993 transmission. I swapped out the main harness along with the vacuum harnesses and vacuum line assemblies. I also had to change the alternator harness and oil pressure sensor wiring. Last but not least the two trans mission harness were changed as well.
Everything works but heres the problem, when I turn the key the car motor turns and turns but will not start just acts like it wants to start but won't. Around the time I first finished completely modifying everything I could think to swap out. The car would start after about 10 trys’ would cut it and it would start right back up with no problems as long as the motor was warm. Motor cools off no start until many try’s. it’s been 5 months and now the car dose not start at all no matter how many try’s in turning the engine over. The car attempts to start but won't. Car has fuel pressure and spark, although I have not checked for how much psi pressure or resistance (don’t have the test equipment to do so). I am ready to call it quits but before I do wanted to ask for your opinion on weather I should change the engine computer from the year of the car (1994) to the year of the new engine (1990)
any suggestions would be great.
Richard
Aug 12, 2007 at 3:34 PM
  • 75,988 POSTS
[quote:79c13d5c23="poet042005"]1990/1994 ford thunderbird 3.8 140,00 miles
Richard[/quote:79c13d5c23]
Car has fuel pressure and spark, all we need now is speed and compression to fire it up.
Check the fuel pressure, it has to be in specs- The EFI don't like pressure that is not up to snuff. Once you do this comeback and tell us.
Or maybe the PCM is totally confused not seeing it and don't know what to do this what happens in modifications when not engineered right.
Aug 12, 2007 at 5:05 PM
Suggested Repair
Verify fuel pressure is within specification, since the EFI system will not start reliably if pressure is low. Also consider that the mixed 1990 engine, 1993 transmission, and 1994 PCM and harness swaps may leave the computer mismatched or confused.
Conversation Summary
A 1994 Ford Thunderbird with a swapped 1990 3.8 engine, 1993 transmission, and multiple harness changes cranks but will not start. It once started after many attempts when warm, then restarted while warm, but now will not start at all. The owner reports fuel pressure and spark but has not measured pressure or resistance, and asks whether to use a 1990 computer. The expert says proper fuel pressure and compression are still needed and that the PCM may be confused by the unengineered modifications.
