1984 Ford Tempo No Spark No Start
VICTOR000
I have a 1984 ford tempo that was working fine, then it stalled some times and now it wont start. It cranks, but the engine will not turn over. I checked to see if fuel was going to the carburator, and it was. Then I checked for a spark, and no spark was coming from the engine. This car has a distributor cap and points. What is worng with my car? cry:
Feb 6, 2007 at 5:41 AM
  • 75,988 POSTS
[quote:a9f230cbed="victor000"]I have a 1984 ford tempo that was working fine, then it stalled some times and now it wont start. It cranks, but the engine will not turn over. I checked to see if fuel was going to the carburator, and it was. Then I checked for a spark, and no spark was coming from the engine. This car has a distributor cap and points. What is worng with my car? cry:[/quote:a9f230cbed]
Check your ignition fuse-then power to the coil-
okay therr-regap the contact points on the high side of the lobe
BTW I don't think! an 84 Tempo has a conventional ignition system-most likely its the ignition control module. On a SSI/EEC systems.
Feb 6, 2007 at 6:11 AM
Suggested Repair
Check the ignition fuse and power to the coil. A 1984 Tempo most likely uses an electronic SSI/EEC ignition rather than points, so test the ignition control module. If contact points are present, regap them on the high side of the lobe.
Conversation Summary
The owner of a 1984 Ford Tempo says it stalled intermittently and now cranks but will not start. Fuel reaches the carburetor, but there is no spark, and the owner believes the car has a distributor cap and points. The expert advises checking the ignition fuse and coil power, and says the no-spark problem is most likely the ignition control module on an SSI/EEC system.
