help! wont start
LIBERTY7
i have a 1992 ford temp gl. approx 100,000 miles 4 cylinders. ok i used my car in the am and then at night i tried to start it and nothing happened. the lights, radio and electric windows and locks worked but the car would not start. i have already changed the ignition switch, bought a new battery and had the starter checked and was told the starter is still good. after all of that the car will still not start. not sure what to do anymore and am getting very frustrated. what should i do next???
Sep 30, 2007 at 10:08 AM
  • 75,988 POSTS
Does it cranks over and refuses to start or nothing when key is turn to start position?
Sep 30, 2007 at 5:34 PM
MARLENE
Did you have your solenoid checked? I had a similar problem with it not wanting to crank and I had a new starter put in and the battery connection was checked and an ignition module replaced.
Oct 12, 2007 at 4:20 PM
