1992 Ford Tempo Starter Keeps Running
92TEMPO92
I have a 92 Tempo GL, 2.3L, automatic. The starter keeps running after the car starts. I replaced the relay on the firewall above the tire well. Everything appears fine. The usual repair manuals don't cover this problem.
Aug 18, 2007 at 6:23 AM
  • 75,988 POSTS
[quote:e347659d89="92Tempo92"]I have a 92 Tempo GL, 2.3L, automatic. The starter keeps running after the car starts. I replaced the relay on the firewall above the tire well. Everything appears fine. The usual repair manuals don't cover this problem.[/quote:e347659d89]
You have a problem with the ignition switch
Aug 18, 2007 at 9:08 AM
Suggested Repair
Inspect and replace the ignition switch. The starter relay was already replaced and did not stop the starter from continuing to run after the engine starts.
Conversation Summary
The owner of a 1992 Ford Tempo GL 2.3L automatic reports that the starter keeps running after the car starts. The firewall starter relay was replaced without fixing the issue. The expert attributes the problem to a faulty ignition switch.
