1994 Ford Tempo Timing Mark
PADDY
I would like to find out where the timing mark is on a 2.3 motor, so I can set engine timing.
Apr 17, 2007 at 7:50 AM
MERLIN2021
  • 17,250 POSTS
there is a notch on the harmonic balance and a statioary pointer on the block. This is of course if you have a distributor!
Apr 17, 2007 at 8:35 AM
PADDY
Thanks for your reply/answer, greatly appreciated.
Apr 18, 2007 at 4:47 AM
Suggested Repair
If the 2.3 engine has a distributor, find the timing mark as a notch on the harmonic balancer and align it with the stationary pointer on the engine block.
Conversation Summary
The owner of a 1994 Ford Tempo with a 2.3 engine asked where the timing mark is so ignition timing can be set. The expert said there is a notch on the harmonic balancer and a stationary pointer on the block, provided the engine has a distributor. The owner thanked the expert.
