1994 Ford Tempo solenoid
1994 FORD TEMPO
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
VIKES261
I just replaced battery and solenoid and car started twice and then heard some noise possibly from the starter and then put back in parking spot and will not start again. You can hear the Solenoid click but will not start. Any help would be great. Coul it be possible that something is connected wrong?
Thanks.
Jan 15, 2008 at 12:21 PM
At the starter relay make sure the relay is grounded properly jump a small wire from the battery side of the relay to I terminal did it crank over?
Jan 15, 2008 at 12:29 PM
VIKES261
[quote:1df2d9b792="rasmataz"]At the starter relay make sure the relay is grounded properly jump a small wire from the battery side of the relay to I terminal did it crank over?[/quote:1df2d9b792] Thanks, I'll try that, any other possibilities if it will not start? Is it possible that one of the wires is not on the correct post of the solenoid? I'm just looking for a couple of more ideas, I find it weird that it would start twice and then just die out and just hear click, click.
Jan 15, 2008 at 12:37 PM
Try that 1st and report back-doing that should kick the starter.also do this when you jump it-put a test light on the other side of the relay-the light should lit at the same time jumping it. If not the relay is bad
Jan 15, 2008 at 12:46 PM
