1987 Ford Tempo Cranks But Won't Run
COACH37
1987 ford tempo, 2.3 , 49000 miles. Car wont start. Kicks over but wont run. If its an ecc relay how do I test it? I read one of your posts that said it coule be the ecc
May 23, 2007 at 3:49 AM
RUDPRO
  • 224 POSTS
The first thing to do is check for fuel, spark and compression. If you don't have all 3, the car won't run. If you're missing 1 of the three, that will help narrow down what the problem is.
May 23, 2007 at 4:19 AM
COACH37
[quote:60be1b35a4="Rudpro"]The first thing to do is check for fuel, spark and compression. If you don't have all 3, the car won't run. If you're missing 1 of the three, that will help narrow down what the problem is.[/quote:60be1b35a4]
It does turn over but then dies
May 23, 2007 at 4:31 AM
Suggested Repair
Check for fuel, spark, and compression. If any one is missing, use that result to narrow down why the engine cranks but will not stay running.
Conversation Summary
The owner of a 1987 Ford Tempo 2.3 says the engine cranks but will not run and asks how to test the ECC relay. The expert advises checking fuel, spark, and compression first. The owner then clarifies that it turns over and then dies.
