when I start my car the temp gauge is on cool, I drive it about 5 miles it immediately rises to hot but the car does not overheat. The check engine light also comes on. I changed the thermostat, plugs & wires, PCV valve, and it is full of coolant with no leaks. I also changed both of the O2 sensors in the exhaust system. When I stop and leave the engine running the radiator fan races at a very high speed. I also had some heater problems last year. It would blow but not get very hot. Any advice would be appreciated.
Apr 9, 2009 at 2:53 AM
