Temperature gauge stuck in cold position, temperature sensor location needed
94,000 MILES • 4 CYL • 2WD • AUTOMATIC
MDANIELS01
Gauge on Instrument panel is parked in the cold position, but there is no problem with heat. Which temperature sensor needs changing, and where is it located?
Thank you!
Jan 28, 2009 at 8:39 AM
FIXITMR
  • 9,989 POSTS
According to replacement part pictures it has a small threaded post for a connector in stead of the common large plastic plug style. Has a push on rubber wire end similar to starter relay ignition input. Haynes manual shows it located slightly forward of center under thermostat housing on right side of head.follow upper radiator hose to thermostat housing.thermostat housing itself has two coolant sensors on top that have plastic plug in connections.these are for the radiator fan and the computer. You can see the temperature sensor by looking over behind back of ignition coil mount. You will have to remove air box and rubber ducting to get clear access. Before replacing you should check for corrosion of connector. Also ground the connector wire to engine block to test gauge circuitry function.
Jan 31, 2009 at 5:56 AM
PATRICKSKACK
Hello
Sep 4, 2018 at 12:40 AM
  • 55,628 POSTS
Can we help you with something?
Cheers, Ken
Sep 4, 2018 at 2:55 AM
