1993 Ford Tempo Speedometer Drive Gear Fix
PAPS
my 1993 tempo 4 cyl. with 89000 miles needs the speedometer drive gear replaced how do i remove the retaining screw from the retainer assembly ?
Feb 24, 2006 at 11:02 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:a24e6ad7a8="paps"]my 1993 tempo 4 cyl. with 89000 miles needs the speedometer drive gear replaced how do i remove the retaining screw from the retainer assembly ?[/quote:a24e6ad7a8]
Using a suitable wrench, remove the retaining screw from the speedometer drive gear retainer assemble.
That's all the book says. Looks like it is a nut from the illustration.
Good luck. :)
Feb 25, 2006 at 7:17 AM
Suggested Repair
Use a suitable wrench to remove the retaining fastener from the speedometer drive gear retainer assembly. The service illustration indicates the fastener is a nut rather than a screw.
Conversation Summary
The owner of a 1993 Ford Tempo 4-cylinder with 89,000 miles asked how to remove the retaining screw from the speedometer drive gear retainer assembly. The expert said the manual only instructs using a suitable wrench and noted that the illustration appears to show a nut.
