You basically remove all the bolts and pry off! It is glued from the factory with silicone! You have besides the the block bolts some pipe bolts on pass side and larger trans bolts on drivers end! Have fun! You may have to pull starter first! Also a bracket or 2?Try a google search! There may be a how to already on the net! I found 1 for a saturn on you tube! You can also look up your local library mechanics reference/guides online if you have a card#.
SPONSORED LINKS
Wednesday, May 20th, 2009 AT 6:55 PM
