HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Tempo
Engine
Cylinder Head
Valve Cover
Gasket
Replace/Remove
SPONSORED LINKS
1992 Ford Tempo
DONAVAN1
MEMBER
1992 FORD TEMPO
4 CYL
2WD
AUTOMATIC
134,000 MILES
I replaced the valve cover gasket on my car and it's still leaking oil, any other ideas of where it may be leaking from?
Wednesday, September 15th, 2010 AT 1:25 PM
WRENCHTECH
MECHANIC
I'm not there to see it. Your just going to have to clean it real good and find the source of the leak.
SPONSORED LINKS
Wednesday, September 15th, 2010 AT 1:42 PM
FIXITMR
MECHANIC
Common leaks are the oil pressure sender and the oil pan and crankshaft seals. Oil filter can leak too.
Thursday, September 16th, 2010 AT 10:32 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Valve Cover Gasket Replace/Remove Content
1994 Ford Tempo Valve Cover Gasket
What Are The Torque Requirements For The Valve Cover On A 94 Ford Tempo
Asked by
Kimra1962
1994
FORD TEMPO
Oil Coming Of Valve Cover
. My 93 Tempo 4cyl Leaks Oil From Oil Breather Cap To Air Filter.
Asked by
JOHN TEMPO93
1 IMAGE
1993
FORD TEMPO
1994 Ford Tempo How To Change The Head Lights
Passenger Side Headlight To Be Changed. How Could I Do That. I Can Remove The Wire From Inside But I Don't See The Bulb. Do I Have To Remove...
Asked by
Stansingar
1 ANSWER
1994
FORD TEMPO
1992 Ford Tempo Where Is The Oil Pan?
Noises Problem 1992 Ford Tempo 6 Cyl Two Wheel Drive Automatic We Can't Find The Oil Pan And The Oil Light Is On
Asked by
homemom12
1992
FORD TEMPO
1992 Ford Tempo, Timing Belt?
1992 Ford Tempo, I Just Bought The Car, Was Told That The Timing Belt Was No Good. I Took Off The Oil Cap And When The Car Is Cranking...
Asked by
dunthatb4
1992
FORD TEMPO
VIEW MORE
SPONSORED LINKS
Engine Oil Leak
Black Smoke
Engine Oil Change and Filter Saturn Vue
Online car repair manuals
