If using original bolts to secure cover, apply small amount of Loctite or equivalent to bolts before tightening. Tighten each bolt to 71-106 inch lbs. (8-12 Nm).
If using nuts to secure the covers( 3.0L engine) refer to diagram of order of tightening the nuts. Tighten each nut, in order, 8-10 ft. lbs. (10-14 Nm).
Thanks for using 2CarPros.com!
Mar 23, 2009 at 12:00 PM
