1991 Ford Tempo car won't start
MELISSAREEDER
  • 1991 FORD TEMPO
1991 Ford Tempo 4 cyl Two Wheel Drive Automatic
where is the fuel pump shut off button located and what does it look like
Monday, July 6th, 2009 AT 10:06 AM
FIXITMR
  • 9,990 POSTS
The ones i've seen are in the trunk on drivers side metal support brace behind liner panel. In front of strut tower. On the backside of brace. Unbolts from frontside. You can access switch without taking off. I take it your fuel pump is not running? You can take plug off unit and test for 12v power.
Monday, July 6th, 2009 AT 10:48 AM
