1991 Ford Tempo Blinkers will not work
1991 FORD TEMPO
KMORTON12
Electrical problem
1991 Ford Tempo Front Wheel Drive Automatic
I have changed the fuse for the blinkers many times. I know there might be a short in the steering column, but the blinkers have worked before. Is there anything else I can try to get them to work before I take it to the shop?
Aug 24, 2009 at 6:00 PM
Might want to replace the flasher unit
Aug 24, 2009 at 6:14 PM
RAINMAN01
HI,
I am guessing that you checked, but do the emergency flashers work?
Dennis.
Aug 24, 2009 at 6:30 PM
FIXITMR
  • 9,990 POSTS
when did this problem start? does it matter which way you turn to blow fuse? do you notice blinkers quit?fuse blow when you turn? has car ever been in accident?
Aug 26, 2009 at 12:05 AM
