Electrical problem
1991 Ford Tempo 4 cyl Front Wheel Drive Automatic
When I turn on blinker to turn left, the panel indicator light stays on - no blink. Neither the front nor back turn signal comes on outside. It is not the back bulb as I have checked it. Cannot figure out how to get to the front bulb. Is there a siimple way that I'm just not seeing. Or should I check fuses. If I should check fuses could I get a fuse panel diagram. I bought car used and have no manual. Thanking you in advance. Julee
May 31, 2008 at 2:42 AM
