1994 Ford Taurus Highway Ping
Suggested Repair
Compression of 160 psi on every cylinder is even and acceptable, though slightly below the expected 180 psi. For occasional highway ping, replace the EGR valve with an updated Ford unit and clean the EGR passages without removing the upper intake manifold.
Conversation Summary
The owner of a 1994 Ford Taurus 3.0 with 65,000 miles measured 160 psi compression on every cylinder and asked whether that was acceptable, citing occasional pinging at highway speeds despite timing being retarded slightly. An expert said the even readings indicate a good engine, though about 180 psi would be excellent, and a wet test would likely read higher. For the ping, the expert recommended installing a new updated Ford EGR valve and cleaning the EGR passages without removing the manifold.
