1996 Ford Taurus Will Not Start
RANORRIS87
I have a 1996 Ford Taurus with about 110,000 miles. This morning it started fine then when I was leaving later on it would not even turn over. I can hear a slight clicking from the engine, the solenoid maybe? I tried jumping it but nothing. Any help would be appreciated.
Apr 8, 2006 at 6:10 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:e540bacd27="ranorris87"]I have a 1996 Ford Taurus with about 110,000 miles. This morning it started fine then when I was leaving later on it would not even turn over. I can hear a slight clicking from the engine, the solenoid maybe? I tried jumping it but nothing. Any help would be appreciated.[/quote:e540bacd27]
Charge the battery, clean the connections and check the serpentine belt condition and tension. Most large auto parts chains will charge and test the battery free of charge. No pun intended. :)
Good luck and let us know. :?:
Apr 8, 2006 at 3:38 PM
RANORRIS87
Thanks for the help, after a little more proding around I found it was a bad starter motor, got it fixed in no time with a replacement. It works but I am $350 lighter now! :D
Apr 8, 2006 at 4:32 PM
PEPPERMRJ
  • 1,158 POSTS
Ouch! :shock:
Thanxs for the update. Happy motoring. :)
Apr 8, 2006 at 4:34 PM
Suggested Repair
Charge and test the battery, clean the connections, and check serpentine belt condition and tension. In this case, further inspection found a bad starter motor, which was replaced.
Conversation Summary
A 1996 Ford Taurus with about 110,000 miles started earlier but later would not crank, with only a slight click, and jumping it did not help. The expert advised charging and testing the battery, cleaning connections, and checking the serpentine belt. The owner later reported that a bad starter motor was the cause and that replacing it fixed the no-crank problem.
