what's the kind of oil i should use for a ford taurus 2002?
May 3, 2006 at 7:39 PM
Use the manufacturer-specified viscosity, typically 5W-30 below about 70,000 miles. 10W-30 may be acceptable above 70,000 miles or in very hot conditions. Avoid 10W-40 unless the vehicle specifically calls for it, and change the oil regularly.
The owner asked which oil to use in a 2002 Ford Taurus. The expert recommended 5W-30 under about 70,000 miles and 10W-30 above that, preferring Castrol GTX. After the owner mentioned Shell Rotella T, the expert said matching the specified viscosity is most important, noted that Rotella T is a diesel oil with extra detergents, and advised against 10W-40 unless specified.
