My car drives for about 10 min and then dies. I can wait for about 30 or 40 minutes and it will start back up and repeat it self all over. This has been going on for over a weak. I have put a new coil pack and thats not the problem. It is a 1993 ford taurus sho 3.2. Can you ppease tell me what might be the problem. Thankyou.
SPONSORED LINKS
Saturday, November 3rd, 2007 AT 11:08 PM
MERLIN2021
MECHANIC
Is the check engine light on? If yes get the codes read, you can buy scanners real cheap for this car. The codes will tell you where to look! If no codes then test your fuel pump, and crank sensor.
